2003 Ford Focus Heater/Aircondition
81,264 MILES • 4 CYL • FWD • AUTOMATIC
GUSS11
When I turn my heat or air on-- I can only run it on 1 or 2. If I turn it any higher it slowly shuts off. The air is cold when running and the air is hot when running. I have replaced the resistor and that did not help.
Oct 13, 2010 at 4:35 AM
WRENCHTECH
  • 20,758 POSTS
[quote:f0b393d49f="Guss11"]Heater problem
2003 Ford Focus 4 cyl Front Wheel Drive Automatic 81264 miles
When I turn my heat or air on-- I can only run it on 1 or 2. If I turn it any higher it slowly shuts off. The air is cold when running and the air is hot when running. I have replaced the resistor and that did not help.[/quote:f0b393d49f]
None of that made any sense at all. You want to try again and explain it a little clearer?
Oct 13, 2010 at 7:44 AM
