EGR hose/pipe replacement
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
SYLVIA2555
  • 8 POSTS
I need directions and pictures on replacing the EGR hose/pipe....Thanks
May 24, 2010 at 7:49 AM
RENAUDTN
  • 636 POSTS
It’s a very straightforward job: disconnect the two rubber hoses that go to the DPFE sensor (make a note of which one goes to which port on the tube), unbolt the tube at the exhaust manifold (2 bolts) and at the EGR (may be pretty tight, and rusty; use some liquid wrench if needed). When installing the new EGR tube, make sure to install a new EGR tube gasket at the manifold ($2), and reconnect the two hoses.
May 26, 2010 at 4:52 AM
