egr clean or replace
2000 FORD FOCUS
150,000 MILES • 2.1L • 4 CYL • RWD • AUTOMATIC
RATTMAN62
rough idle dies out at stops
Jan 23, 2016 at 11:21 AM
WRENCHTECH
  • 20,761 POSTS
First eliminate all vacuum or air leaks in the system (very important)
. You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Jan 23, 2016 at 11:53 AM
