2003 Ford Focus Check Engine light illuminated, why?
84,000 MILES • 4 CYL • 2WD • AUTOMATIC
CH122417
Need help please,
I have a 2003 ford focus 4 cylinder with a 2.3 L PZEV emission efficient engine. My check engine light is on and I can't figure out why, nor know where to start.
I looked for the PCV valve and air filter so I could change them out. Could not find either. Through blogging I've read that a PCV valve and air filter are not present in this vehicle, or have been designed to be maintenance free. Therfore they do not need to be changed. Is this correct?
Also, where would I start looking to find what is causing the error code? Would the oxygen sensor be the culprit?
The engine is in fine running shape, no obvious problems. Please help!
Thanks
Nov 22, 2008 at 7:42 AM
DOCFIXIT
  • 18,828 POSTS
Go to an Auto Zone have codes read the post in P0xxx format.
Nov 22, 2008 at 8:05 AM
