2003 Ford Focus
88,234 MILES • 4 CYL • FWD • AUTOMATIC
DONSTER
if the oil drain plug breaks off and goes into the pan will it do damage of pan is not removed and the broken piece is not removed
Apr 12, 2009 at 1:48 AM
BLACKOP555
  • 10,386 POSTS
how big of a piece? if its half the bolt dont worry about it. thats alot of weight and will stay at the bottom of the pan. may cause teh oil to slow down if it goes over teh hole when draining it. it wouldnt get sucked up the oill pump tube as it has a screen on it. and it wont bounce up into the crankshaft.
Apr 12, 2009 at 2:12 PM
