Have you tried to jump start the car?
Many times the battery will have enough power to turn on the radio and light but not enough to start the engine.
https://www.2carpros.com/articles/how-a-car-battery-works
If you are able to jump start it then all you will need is a battery.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
If it still just clicks then you will have to have a look at the starter relay and the starter.
The relay is located under the hood, in the fuse box.
It can be tested as well.
Replacing the starter can be done using simple hand tools. The starter is mounted by two bolts.
Here are some helpful article:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
SPONSORED LINKS
Thursday, August 5th, 2021 AT 8:13 PM
