2002 Ford Focus window regulator
DWCARON
2002 Ford Focus 4 cyl
how do you remove the rear driver power motor window regulator
Jul 9, 2008 at 3:22 AM
KHLOW2008
  • 41,812 POSTS
Hi dwcaron,
Remove door panel.
Lower glass so that the mounting bolts can be taken off.
Disconnect motor wire connector
Remove all bolts attaching the motor and regulator.
Regulator can be taken out
Jul 9, 2008 at 3:41 AM
