2002 Ford Focus oil pan
143,000 MILES • 4 CYL • FWD • AUTOMATIC
MRTWSTRS
I have new oil pan that i need to put on but the parts store keeps telling me that theres an upper oil pan and a lower. the lower is the problem. Does the upper gasket have to be changed or can i drop lower pan and put new one in? also do i have to drop exauhst?
Mar 11, 2010 at 5:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
just replace lower if its only one bad and you will have to remove the catalytic converter , yes.
Mar 11, 2010 at 5:45 AM
