2002 Ford Focus imrc module
2002 FORD FOCUS
169,000 MILES • 4 CYL • FWD • MANUAL
CAMILLISJETBLEU
found that the cable pulled out and broke from inside the aluminum housing. bought a new one. how do i install it? thanks Ed
Sep 15, 2010 at 2:51 AM
BMRFIXIT
  • 19,053 POSTS
Remove air cleaner outlet tube.
Disconnect Mass Air Flow (MAF) sensor electrical connector.
Disconnect breather pipe.
Remove the air cleaner.
Rotate the Intake Manifold Runner Control (IMRC) lever counterclockwise.
Disconnect the IMRC actuator cable from the IMRC lever.
Release the IMRC actuator cable locking tangs.
Sep 15, 2010 at 1:49 PM
