2002 Ford Focus I see boilling water in deposit
2002 FORD FOCUS
56,234 MILES • 4 CYL • 2WD • MANUAL
COLORMADERA
There is something curious due temp alert looks normal right at the middle and this boilling occurs sometimes not all times when I stop the engine I can hear at the reservoir boilling water and lot of bubles in and out the plastic reservoir. When I say water I mean coolant / water mixed. Tks.
May 14, 2010 at 5:29 PM
  • 31,937 POSTS
Hi there,
Check the thermostat, flush the cooling system, test the pressure cap and get the radiator flushed and flow tested, start here.
mark (mhpautos)
May 14, 2010 at 6:34 PM
