2002 Ford Focus heater blower
2002 FORD FOCUS
41,000 MILES • 4 CYL • 4WD • MANUAL
MOHSENABUSAIDI
the heater blower does not work
Nov 21, 2008 at 10:09 PM
BMRFIXIT
  • 19,053 POSTS
Doesn't work at all not at any speed
check fuses
locate blower motor and unplug wiring connector
connect test light between the two terminals
place switch at high light should come on
if so motor no good and need a new blower motor if not recheck fuses and check wiring
check ignition switch
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 21, 2008 at 10:20 PM
