fuel pressure?
11,000 MILES • 4 CYL • FWD • AUTOMATIC
CLAUDE PRéFONTAINE
fuel pressure specs for zetec 16 valve 2 liter engine?
May 26, 2010 at 3:46 AM
DOCFIXIT
  • 18,828 POSTS
From 35 - 65 psi here is a guide to help you see how to check the fuel pump pressure.
If your vehicle doesn't have a schrader valve on the fuel rail, you will need a fuel injection test kit to tap into the line either after the filter or where the line attaches to the fuel rail
Cheers
May 26, 2010 at 4:05 AM
WHATS A DIESEL
Ive a focus diesel tdci that stopped running after about 20 miles from its last service. My local mechanic says it low on fuel pressure he changed the fuel filter but it still wont run. im trying to fix it myself but not sure where to start. can anyone help.
Oct 3, 2018 at 10:53 AM (Merged)
RENAUDTN
  • 636 POSTS
Have you checked the fuel pump? Also, check your fuel lines for leaks, and your fuel pressure regulator (remove the vacuum line connected to it, and check inside for fuel; if there is fuel inside the vacuum line, replace regulator). - This year don't have a regulator it's regulated by pcm?
PABLOWDIDIT
Sounds like you could use some help ,I used to have a diesel Ford Tempo 86 and after 200.000 I had some trouble with the head gasket ,Some one drove it before i bought it and ran it with out Pres~tone in it and over heated it,then i bought it with out knowing ,changes the head gasket had the head shaved and never did get it running right , Had to scrap it in the end.
Regards and good luck,also could just be air in the system some where ,Pump/filter could even be electric problem it sounds like it was running good before you went to that shop ,probably some thing to do with that chow friend .Silly question but "did some one put gas in it ? that sounds right on the mark too .
RANDY SHARP
  • 165 POSTS
I have a 2003 ford focus zx3 2.3 L. These vehicles have no place to place a fuel pressure gauge I have looked through all over. So how do you check your fuel pressure the only thing I can think of is cutting the fuel rail or taking it to a shop where they have the machines but I will never take my vehicle to a shop unless I am getting a smog. Does anybody have any other ideas.
  • 55,694 POSTS
You need to tap in by the engine where it connects from the frame to the fuel rail. Here shows the gauge set you can rent for free at the auto parts store which will come with the adapter to tap in
Check out the diagrams (Below)
Cheers, Ken
NAVATHOR3
please supply fuel pressure specifications and fuel pump amperage draw key on and engine running.
HMAC300
  • 48,601 POSTS
we have no amp draw specs pressure should be 35-55 psi with key on only. auto parts rent it see link. if it blows the fuse it is too much draw or wire shorted out.
JDMILLER
I have a 2000 ford Focus and it has a fuel starvation problem. Last week a new fuel filter and fuel pump assembly was installed. Everything was fine for the first 250 miles. Then the problem started again. I have a scanguage II installed in the car and today I noticed the when I put my foot in it the FPR(fuel pressure) drops down to 7-8 when the fuel starvation occurs. Normally it is in the range of 25-41. So what is the correct range for the FPR? What could cause this problem? This problem has just about broken the bank..
HMAC300
  • 48,601 POSTS
pressure shold be 35-55psi, check for a bad regulator or maybe the fuel filter was installed backwards
LAZAROIM
Engine Performance problem
2001 Ford Focus 4 cyl Front Wheel Drive Manual
what's the fuel pressure for this car?
BMRFIXIT
  • 19,053 POSTS
fuel pressure for 2.0L engine 35-65 PSI
