2002 Ford Focus Front wheel bearing
JESTR
Drive Train Axles Bearings problem
2002 Ford Focus 4 cyl Front Wheel Drive Manual
I have a 2002 Focus ZTS. The front drivers side wheel bearing started making noise last week. I bought the hub assembly from the parts store only to find the hub and bearing need to be pressed in. My question is, Can you tell me if once the bearing is pressed on the hub if it has to then be pressed on the spindle of the car?
Apr 14, 2008 at 3:34 AM
BMRFIXIT
  • 19,053 POSTS
I have to say you need to press in the bearing in 1st then the hub go after that
u have a retainer ring at the rear that you have to remove watch for it
Apr 14, 2008 at 1:11 PM
