2002 Ford Focus Coolant leak
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
TKACHUK51
Antifreeze coolant is leaking out of the drivers side of the engine... It is not near a hose connection. It seems that the I can see the leak because it is bubbling where it is coming out. Help?
Dec 28, 2009 at 5:15 AM
KYCAT420
i have the same make and year 2002 ford focus,and my coolant is leaking the same way, on the drivers side as it goes to the engine block,sometimes it leaks alot sometimes not at all,i put some stop leak in and it seemed to help quite a bit.
Dec 29, 2009 at 3:33 AM
