2002 Ford Focus broken drivers window
108,000 MILES • 4 CYL • FWD • MANUAL
FOCUS2.0GHIA
hi 2 all, i own a 2002 2.0 ghia focus my drivers window is not working although i can operate all the others and lock and unlock the rear ones no probs i have replaced the window motor had a good look at the regulator all seems fine except the motor is not getting its signal to work we have tried but cant seem to be able to locate the window relay anywhere the system is one touch with 8 pins on the motor can anybody help it would be massively appreciated as its been 3 months with no window now. thanks dave
Aug 6, 2009 at 4:12 AM
MIKE H R
  • 3,094 POSTS
I would check the switch itself. if the other windows work that is what I would look at. . the window relay would be under the dash on the drivers side.
Aug 24, 2009 at 1:45 AM
