2002 Ford Focus BLOWER FAN
2002 FORD FOCUS
215,000 MILES • 4 CYL • FWD • AUTOMATIC
WILLY2
HAVING PROBLEM WITH BLOWER FAN. ITSTARTS WHEN I TURN THE SWTCH IT ON RUNS FOR THREE MIN AND STOPS. I HAVE ALLREADY CHANGED THE SWITCH RESISTER ON THE FIRE WALL.wHAT IS THE PROBEM AND HOW DO I FIX IT.
THANKS
Sep 5, 2009 at 6:14 AM
KHLOW2008
  • 41,814 POSTS
Hi WILLY2,
Thank you for the donation.
When blower fan motor stops working, did you test the motor? Try banging the blower motor housing to check if fan starts working. If yes, the motor is failing and requires replacement.
Sep 5, 2009 at 6:32 AM
WILLY2
it runs on all speeds for about 2 min and stops
Sep 5, 2009 at 7:50 AM
WILLY2
it runs on all speeds for about 2 min and stops. where is the motor
Sep 5, 2009 at 7:55 AM
KHLOW2008
  • 41,814 POSTS
The blower motoris behind right side of dash ( glove box). Stretch your habd under the dah and bang the housing to vibrate the motor to see if it works.
Sep 5, 2009 at 9:53 PM
