HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Focus
Engine
Symptoms
Revs Up
2002 Ford Focus 1.8 LX
ALICIAROPER
MEMBER
2002 FORD FOCUS
Engine Performance problem
2002 Ford Focus All Wheel Drive Manual 113.00 miles
just bought a ford focus 1.8 lx needel keeps jumping and missing rev wht does this mean
Monday, May 31st, 2010 AT 1:44 PM
MECHANIC
Hi there,
I would start off with a full tune up, check for vacuum leaks and a scan for any unresolved fault codes, this should show up any problems, start here.
Mark (mhpautos)
Monday, May 31st, 2010 AT 5:21 PM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
2002 Ford Focus High Rev
When Driving Car It Will Randomly Rev High When Attempting To Shift While Accelerating. It Will Drop Down Once I Let Off Of The Accelerator.
Asked by
Khaught3
2002
FORD FOCUS
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
When Stop Drops Under 1,000 Rpm's And Stalls
When I Come To A Stop My Battery Light Comes On And It Drops Under 1,000 Rpm's And Dies No Sputter No Nothing The Charging System All Tested...
Asked by
Robert85
2 IMAGES
2001
FORD FOCUS
Rpm's Stay High After Stopping But Drop To Normal...
I Am Trying To Diagnose Problem With High Rpm Which Only Happens After I Drive Above 45 Rpm. Background Is The Listed Above Has A Zetec...
Asked by
alexv55
2000
FORD FOCUS
Rev's Go High
After A While Of Driving The Rev's Quickly Go Up Then Drop Down Again.
Asked by
John O Flynn
2005
FORD FOCUS
Misfiring In Low Revs
I Have A Mk 2 Ford Focus With 60,000 On The Clock It Has Developed A Misfire And Really Struggles In Low Revs Between 1-3 I Have Change The...
Asked by
stronge9691
2005
FORD FOCUS
VIEW MORE
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
