2002 Ford Focus 1.6 ford focus zetec 02 plate
MEATHIAZANETH
Engine Mechanical problem
2002 Ford Focus Two Wheel Drive Manual
it is described by the garage as having a little end broken connection crankshaft to piston - would buying this part be a replacement or would I need something else
Ford focus 1.6 crankshaft assembly 2007 16v crank shaft in good used condition.only covered 4,400 miles. Complete with shells.
Also could you let me know how big a job I might be looking at and if to replace a larger piece of the engine (cylinder head?) with a scrap part would be easier could you let me know what i would need to get
I look forward to your response and would greatly appreciate any help you can give.
I will attach a picture of the proposed part for information
[img:fda8fd67cc]http://www.2carpros.com/forum/automotive_pictures/309169_7c80_1_1.jpg[/img:fda8fd67cc]
Jan 28, 2009 at 7:11 AM
DAVE H
  • 13,383 POSTS
to replace this part you have to strip the whole engine down .. the part arrowed in the photo is the part you would be buying .. I don't think a 2007 focus part would fit into a 2002 focus .. you would have to check into this ..replacing the cylinder head would not rectify the fault described .. the other option you have is to buy a complete new/recon engine ...
https://images.2carpros.com/forum/automotive_pictures/266999_focus_1.jpg
Jan 28, 2009 at 11:38 AM
