2002 ford focus
IBENATOR
my code reader says i have a misfire in cyl 4. i changed the plug and wire and still get the same reading. what else can i do
Oct 20, 2007 at 8:58 AM
BLACKOP555
  • 10,386 POSTS
bad fuel injector or a bad point in distributor cap.
Oct 20, 2007 at 2:15 PM
SERVICE WRITER
  • 9,123 POSTS
You can check for a vacuum leak. Sounds like spark isn't the issue. Spray some carb cleaner around the intake manifold and see if there is a idle fluctuation.
Can compression test the cylinder...
Oct 20, 2007 at 2:19 PM
