2002 Ford Focus
WOLVES2005
Brakes problem
2002 Ford Focus Manual
Brakes failed suddenly, brake pedal will now touch the floor and braking is minimal at best.
Changed the brake pads but the problem persists. Took one of the air-pipes off & the air-intake is minimal. Instincts say ABS or the servo. Brake-fluid levels are fine, any other suggestions?
Jun 5, 2010 at 4:47 AM
  • 110,246 POSTS
If the brake pedal is going to the floor, either you have a leak or the master cylender is bad.
Jun 7, 2010 at 3:34 AM
