2002 Ford Focus
REDNECK1861
Engine Mechanical problem
2002 Ford Focus 4 cyl Two Wheel Drive Automatic
how to set the timing
May 31, 2010 at 1:52 AM
OBXAUTOMEDIC
  • 3,713 POSTS
Ok, are you replacing the Timing Components or trying to set timing like on older Distributor Engines.
If trying to set timing then you cannot it is Electronically Controlled by the Cam and/or Crank Sensor.
If looking for Setting Timing Marks then check out link below...
https://www.2carpros.com/car_repair_information/year/2002/make/ford/model/focus/2002_ford_focus_timing_belt_diagram_marks.htm
May 31, 2010 at 2:05 AM
