My code reader says I have a misfire in cyl 4. I changed the plug and wire and still get the same reading. What else can I do
Saturday, October 20th, 2007 AT 3:58 PM
BLACKOP555
MECHANIC
Bad fuel injector or a bad point in distributor cap.
SPONSORED LINKS
Saturday, October 20th, 2007 AT 9:15 PM
SERVICE WRITER
MECHANIC
You can check for a vacuum leak. Sounds like spark isn't the issue. Spray some carb cleaner around the intake manifold and see if there is a idle fluctuation.
