[quote:0d7697ea85="lovonda"]Steering problem
2002 Ford Focus 4 cyl Four Wheel Drive Automatic 90000 miles
Hello I put in my key to start up the car and the key will not turn at all... for me to start the car up. I tried to turn the steering wheel but it will not turn anymore and I can not turn the key once I put it in the key hold[/quote:0d7697ea85]
Hi, These cars have a history of the ignition lock cylinder wearing out very quickly. I have replaced several and the insides literally turn to metal dust. I have also noticed that the replacement locks wear out just as fast as the originals. Other than to just keep changing them there's not much you can do. Ford has the attitude that it is not a big enough problem to issue a recall. You should keep in mind that these have the security feature built into the key, and replacement ones will need to be programmed. With that said, there is a trick. After replacing the cylinder, you can tape the old key underneath the plastic cover next to the pickup ring that surrounds where the key goes into the switch. The car will think you are using the old key and will let it start. Hope this helps!!
Jan 9, 2009 at 4:35 AM
