2002 Ford Focus
MARCOVELARDE
Engine Cooling problem
2002 Ford Focus 4 cyl Automatic 81000 miles
I am having problems with my 2002 ford focus it started heating up when iwould come to a stop,but once i would accelerate it would drop to normal.I replaced the thermostat and the problem still happened.I was told to flush the system and did so.the car was normal for about three days until it started doing it again not as much as the first time.Now after three days of driving it its doing what it did before it does it heats up while slowing down or while in park.Ireved the engine while in park when it was oer heating and the needle dropped,but strarted going up after letting the car just sit there.I noticed that when the ac gets turn on the gauge drops down when it was high.waht might be the problem? is it the radiator that is plugged?
Jun 12, 2008 at 12:47 PM
BMRFIXIT
  • 19,053 POSTS
It sound like you have a poor circulation in the system
check radiator
check water pump and coolant flow
check coolant fans
Jun 12, 2008 at 1:00 PM
