2001 Ford Focus won't start
TEMARR
  • 2001 FORD FOCUS
  • 4 CYL
  • FWD
  • 90,000 MILES
The car started for a few seconds and now all it will do is click. The battery is good and it' will not jump.
Wednesday, December 17th, 2008 AT 1:20 PM
Get the battery load tested-make sure its cleaned and properly tightened then try again-don't work the problem could be coming from the igntion switch, park and neutral switch/sensor, starter relay and starter itself.
Wednesday, December 17th, 2008 AT 1:45 PM
DAVE H
  • 13,383 POSTS
Check connections to starter motor. Tap the starter a couple of times with a hammer. Try starting again?
Wednesday, December 17th, 2008 AT 1:58 PM
