2001 Ford Focus Wishbone Bushes
NIKKITA
Suspension problem
2001 Ford Focus 6 cyl Two Wheel Drive Manual
My focus developed a nasty creaking suspension noise and a friend greased all joints etc but it didnt cure it .. now i've been told that its prob the wishbone bushes and that I need ro replace the arms not just the bushes (which I found online)..I'm not a mechanic, just a girlie who loves her car so please can you tell me what is best to do to fix my car (please dont say large garage as I cannot afford that)
Mar 7, 2009 at 10:18 PM
BMRFIXIT
  • 19,053 POSTS
Do you hear it standing still and as you turn the wheels left or right ]
and if so dry ball joint and or outer tie rod end
I do not believe u can grease them ball joint and or the tie rod ends if they never changed no grease fittings on them
Mar 8, 2009 at 12:28 AM
NIKKITA
Thanx for your reply BMR.
I hear the problem all the time while i'm driving & when i'm breaking, its sounds like an old bed spring creaking..also I hear the noise when I am getting in and out of car..its like when you depress/release pressure on the front drivers side front. Yes also when standing still turning steering wheel, but not quite so loud.
A friend tried to change front wishbone bushes today but couldnt get them in as didnt have a tool to do it, apparently needs some sort of 'compression' tool?
Mar 8, 2009 at 9:19 AM
BMRFIXIT
  • 19,053 POSTS
I would start with the outer tie rod ends 1ST
and than the lower ball joints
before u do the bushings
pass it on and let them check it for you we do them all the time and its very easy to over look
jack the tire off check if the noise go away
good luck
let me know
Mar 8, 2009 at 11:42 AM
NIKKITA
Hi BMR ..
thanx for that, i'll pass on the info & let you know the outcome
Mar 8, 2009 at 12:38 PM
