2001 Ford Focus Water Pump and Timing Belt andpulleys
98,000 MILES • 4 CYL • 2WD • MANUAL
BILLY BOLLAND
To change water pump and Timing belt with pulleys ,what will the cost be ?
Could the pump bearing have gone due to low water ?
Sep 5, 2010 at 10:58 PM
  • 31,937 POSTS
Hi there,
You will be looking at about 3.5 hrs labour, (check your local labour rates) and parts will be about $200.00 but this can vary as well depending on supplier, pumps can fail with or with out low coolant levels, but at 100K it will probably just be plain worn out!
mark (mhpautos)
Sep 5, 2010 at 11:35 PM
