2001 Ford Focus Vibrations
JENRMOW
  • 2001 FORD FOCUS
  • 4 CYL
  • 100,425 MILES
I recently had theengine mounts replaced on the car, my original complaint was an engine vibration at 50-65 mph. I have noticed that the engine vibration did not stop, and as gotten slightly worse since replacing the mounts. What else could be causing this vibration?
Sunday, November 16th, 2008 AT 5:50 PM
  • 109,885 POSTS
Hi:
My first question is, why do you think it's an engine vibration? Has someone diagnosed that? If it is from the engine, make sure that the trans mounts are in good condition. Sometimes the rubber will collaps and cause vibration to be trasnfered to the frame / body.
Also, where do you feel the vibration more, in the floor or the steering? Or, is it throughout? Are there any sounds related to the vibration?
Thursday, November 20th, 2008 AT 1:14 PM
