2001 Ford Focus Stalling
180,000 MILES • 4 CYL • FWD • AUTOMATIC
CALSPKNS
Check engine light does not come on. Have replaced fuel filter, air cleaner, Oxygem Sensor, used injector cleaner (2).
Usually happens going uphill. Periodically while driving uphill, car begins to lose power and continues until it stalls out. We turn ignition off and then right back on and it runs just fine....until the next time. Again no check engine light comes on. ???????
Sep 18, 2010 at 4:34 AM
  • 110,251 POSTS
Have you checked the fuel pump pressure?
Whenever this happens, have you checked the catalytic converter to see if it is glowing red hot?
Have you checked the crankshaft sensor?
Sep 18, 2010 at 11:54 AM
CALSPKNS
Thanks for the help. Will check these items and let you know outcome.
Sep 19, 2010 at 4:39 AM
