2001 Ford Focus PINGING EXCESSIVE ENGINE USE
70,000 MILES • 4 CYL • FWD • MANUAL
KEVH123
HI
THE PROBLEM WITH MY FORD FOCUS IS REALLY BAD PINGING NOISE FROM THE ENGINE AND EXCESSIVE OIL USE I USE THE CORRECT GRADE OIL FORD SAY 2 USE AND HAVE TRYED DIFFERENT FUEL STATIONS AND EVEN BEEN RUNNING MY CAR ON EXCELLIUM I HAVE NOTICED FROM TIME TO TIME BLUE SMOKE COMING FROM THE EXHAUT AND THE TAIL PIP HAS A RESIDUE OF OIL IN IT.I DONT KNOW IF SOME OF THE SIMPTOMS I AM GETTING IS DOWN TO AFORMER KEEPER LETTING THE OIL RUN DOWN TO LOW CAUSING DAMAGE TO THE PISTON RINGS ORTHE SCRAPER RINGS I AM QUIET CONCERND AS WE ALL KNOW IF IT IS THATI HAVE ABIG EXSPENSIVE BILL I WOULD BE VERY GRATEFUL
Jun 28, 2010 at 5:01 AM
  • 110,248 POSTS
Egine ping is usually caused by one of a few things, cheap fuel, ignition timing, or a bad knock sensor. Has the check engine light ever come on? Has anyone ever checked timing?
As far as oil consumption, a valve ping shouldn't cause that. Has the oil been changed on a timely basis? Did you get the car new?
Let me know. Also, let me know more about the blue smoke you are seeing.
Jul 3, 2010 at 6:52 AM
