2001 Ford Focus Heater Blower Motor Replacement
121,000 MILES • 4 CYL • 2WD • MANUAL
VISHUS
I recently replaced the resistor on the blower motor when it only worked on '4' and shut off on '3'. Altho this did fix that problem - the blower is now squeaking and then grinding - which I assume means it needs to be replaced.
I've taken the glovebox door apart again and can see the unit infront of me.
My question is - how does it come apart? It doesn't look like it's easy to access and I'm not sure where to start.
Any help would be appreciated! Thanks...
Jan 4, 2010 at 9:23 AM
MERLIN2021
  • 17,250 POSTS
Access is remove the screw from underneath, check your email, I sent the complete info from Ford manuals.
Jan 4, 2010 at 9:29 AM
