2001 Ford Focus Ford Focus Refrigerant Refill
89,000 MILES • 4 CYL • FWD • AUTOMATIC
JOBSTUD
WHERE IS THE PORT? Can't seem to find it. Found the high pressure side on the drivers side in front of the radiator, but can't find the low pressure side where the fill line attaches. HELP!
Jun 11, 2008 at 6:07 AM
DAVIDA666
The low side port is on the drier, in front of the right front tire, underneath the plastic wheel well housing. It can be seen from below, but you can loosen the housing to access the port from the side.
Jun 14, 2008 at 4:22 AM
