2001 Ford Focus Engine Overheating
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
GRAYFOX66
Hello
What is the most probable cause of engine overheating.
Where is the cooling fan relay located on the frame.
Thanks
John
Jun 6, 2009 at 10:36 AM
ARGUS
  • 7 POSTS
The most common problems causing engine overheating can be found here:
https://www.2carpros.com/first_things/engine_over_heats.htm
Very well done article including pictures.
I could go over the different issues that could be causing it, but that link will take you to a pretty complete QA.
Good luck!
Jun 22, 2009 at 4:38 PM
