2001 Ford Focus Car will not start
144,000 MILES • 4 CYL • 2WD • AUTOMATIC
SWAY67
Car will not start. Have replaced fuel pump, coil pack, fuel filter, and plug wires. Run fine when I drove it to work and when I came out to get in the car to go home it would not start.
Nov 27, 2009 at 3:15 PM
  • 75,988 POSTS
Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 27, 2009 at 4:17 PM
