2001 Ford Focus car idles high then sputters
91,000 MILES • 4 CYL • 2WD • MANUAL
WENDELL_TATE
My 2001 Focus is possessed. It just started (again) revving really high on its own. It does this with the air on. Without the air on it will sputter and eventually will cut off.
The engine light did come on. This happened before and my local mechanic replaced the oxygen sensor. It has been fine for a couple of weeks but it is back now.
What could cause this?
Oct 10, 2008 at 8:43 AM
RENAUDTN
  • 636 POSTS
If your car idles high, try cleaning your IAC valve, and get your IAC motor checked.
If it doesn't help, you may have to replace them.
Oct 15, 2008 at 5:32 AM
