2001 Ford Focus brake fluid
XOE2MAN
Brakes problem
2001 Ford Focus 4 cyl Two Wheel Drive Automatic
where does the brake fluid go in my car
Dec 9, 2008 at 5:22 AM
  • 75,988 POSTS
In the engine compartment you will see a big black looking round thing called brake booster its in front of it at the drivers side firewall with steel lines attached to it with a reservoir called brake master cylinder assembly -this is where you put the fluid.
Dec 9, 2008 at 5:37 AM
