2001 Ford Focus brake fluid
2001 FORD FOCUS
XOE2MAN
Brakes problem
2001 Ford Focus 4 cyl Two Wheel Drive Automatic
where does the brake fluid go in my car
Dec 9, 2008 at 1:22 PM
In the engine compartment you will see a big black looking round thing called brake booster its in front of it at the drivers side firewall with steel lines attached to it with a reservoir called brake master cylinder assembly -this is where you put the fluid.
Dec 9, 2008 at 1:37 PM
