2001 Ford Focus ac compessor doesnt work
ELISAELISABLUE
Air Conditioning problem
2001 Ford Focus 4 cyl Manual 12500 miles
I have ac problems i try to turn on my ac and it turns on from the inside but the compressor doesnt turn on. Also when I am driving i am parked and it just starts accelerating by itself
Jun 25, 2010 at 11:09 AM
  • 75,988 POSTS
Check if it has freon in it by checking the pressures with a manifold gauges if okay could be a magnetic clutch failure if you apply power direct to the clutch and won't engage the compressor. or an AC relay or pressure switch problem.
Jun 25, 2010 at 11:14 AM
