First remove all the screws in the door panel.
Next step is to remove the window crank if equipped or the power window controls. From there you have to use a trim tool or a long screwdriver and pry on the panel by each of the clips to pop them out. Be careful not to break them. Keep the car in a heated area to keep the plastic more forgiving and less likely to snap.
SPONSORED LINKS
Tuesday, February 24th, 2009 AT 10:29 PM
