2000 Ford Focus water pump leaks
74 MILES • 4 CYL • FWD • AUTOMATIC
ANDY05
how to replace water pump?
Jun 5, 2010 at 3:18 PM
  • 110,248 POSTS
This is what I was able to find for you. Let me know if it helps. NOTE: It identifies the process for different engines. Select the correct one.
2.0L (VIN 3) Engines
Before servicing the vehicle, refer to the Precautions Section.
Drain the cooling system.
Remove or disconnect the following:
Negative battery cable Accessory drive belt Water pump pulley Front cover Timing belt Timing belt tensioner Water pump
To install:
Install or connect the following:
Water pump. Tighten the bolts to 13 ft. lbs. (18 Nm). Timing belt tensioner Timing belt Front cover Water pump pulley Accessory drive belt Negative battery cable
Fill the cooling system.
Start the engine and check for leaks.
2.0L (VIN N) Engine And 2.3L (VIN Z) Engine
Negative battery cable Accessory drive belt Water pump pulley Water pump mounting bolts Water pump
To install:
Water pump with new O-ring. Tighten the bolts to 89 inch lbs. (10 Nm). Water pump pulley. Tighten the bolts to 18 ft. lbs. (25 Nm). Accessory drive belt Negative battery cable
Fill the cooling system to the correct level.
To install:
2.0L (VIN P) Engine
Negative battery cable Accessory drive belt Front cover Timing belt Timing belt tensioner Water pump
To install:
Water pump. Tighten the bolts to 18 ft. lbs. (25 Nm). Timing belt tensioner Timing belt Accessory drive belt Negative battery cable
Jun 7, 2010 at 3:33 AM
