2000 Ford Focus Sutting down
VICKIE HENRY
Engine Performance problem
2000 Ford Focus 4 cyl Front Wheel Drive Automatic
When i drive my car at start up and at stops the car will shake a bit a then shut off .
It will restart with the turn of the key but will shut off at every stop.
Sep 29, 2009 at 3:41 PM
RENAUDTN
  • 636 POSTS
I would start by cleaning the throttle body and throttle plate, as well as the idle air bypass with some throttle cleaner.
It could be many other things but that’s what I’d do first. I would also check for codes.
Sep 30, 2009 at 5:32 AM
