2000 Ford Focus starter ignition system
60,000 MILES • 4 CYL • FWD • AUTOMATIC
TOESHOE
we have a starter problem. when we put in the key it will not start. i cheeked the starter for the proper voltage but it only had four volts. i corrected that problem, and now we have no spark from the coil to the plugs. who can we fix this.
Dec 21, 2008 at 12:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like you have a faulty ignition switch. Check all wiring for any broken spots, shorts or loose fits. Also ensure power is at the switch.
Dec 21, 2008 at 1:24 PM
