2000 Ford Focus Oil Consumption - rings or valves?
90,000 MILES • 4 CYL • 2WD • MANUAL
PRIDDY
Oil consumption on daughter's car is high - no leaks, no significant smoke (including after overrun). One spark plug badly fouled (see picture). Is there an easy way(s) to tell if it is a valve guide .v. rings? Head replacement may be worth the money but whole engine - hmmm?
Oil has probably plugged the cat-converter - which is being fixed now.
[img:ba8ae1ad60]http://www.2carpros.com/forum/automotive_pictures/391770_spark_plug2_1.jpg[/img:ba8ae1ad60]
Aug 3, 2009 at 9:01 PM
  • 31,937 POSTS
Hi there,
For that amount of deposits to build up you would be looking at a ring problem, a leak down test will help determine the blow by and a wet comp test the general condition of the rings, fitting a head will only cause more oil consumption problems, i would be looking at a second hand or re co engine.
mark (mhpautos)
Aug 3, 2009 at 10:34 PM
