2000 Ford Focus mpg
OLDSCHOOL823
Engine Performance problem
2000 Ford Focus 4 cyl Two Wheel Drive Automatic
My 2000 ford focus gets terrible gas mileage
Feb 24, 2009 at 8:03 AM
BLACKOP555
  • 10,386 POSTS
what gas mileage is it getting, i need to know how much it is getting and how much it used to be getting so i can start to make educated guesses on what to check.
Feb 24, 2009 at 2:30 PM
OLDSCHOOL823
It gets 14-18 in city and 25 on highway, thats very low for a 2000 ford focus
Feb 25, 2009 at 4:51 AM
BLACKOP555
  • 10,386 POSTS
im asking what you got before anad what your getting now.
driving habbits affect gas mileage, which is why i dont want to use the stock numbers.
i have to decide how severe it is so i know what parts to look into.
Feb 25, 2009 at 10:41 AM
OLDSCHOOL823
I bought it used so i dont know what it got before. I tried alot of things, air filter, plugs, wires, gas treatments, pvc valve. The check engine lighht was on when i bought but went out after i changed the wires. I'm stumped, any ideas?
Feb 25, 2009 at 10:51 AM
BLACKOP555
  • 10,386 POSTS
you smell raw gas?
tranny slipping?
could be a bad o2 sensor, they go bad and dont throw a code some of the time, could even be an exhaust leaking turn it on and go under it and feel for exahsut, smell for it or look for steam on a hot morning coming out from the leaks.
Feb 25, 2009 at 11:00 AM
KEVIN12881
  • 336 POSTS
thts around a 5mpg drop. you did not mention the mileage and it could be the o2 like blackop555 has ais. also check for the small things like air filter (gat a k& N) or big things like ignition timing. also see incorect idle, low tire pressure, dirty injecters (you already got those) or other problem in fuel injection. one last thing, does it have after market rims or low pro tires? they can have a large impact on MPG
Feb 25, 2009 at 11:14 AM
