2000 Ford Focus lights
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHANTELLE8787
The lights inside my car work when i turn them on, although one of them is not working... when i open my door there is no light that turns on, so i am left in the dark when there is no light. Do i need to replace a light or a fuse? or is it something else?
Aug 30, 2008 at 4:43 PM
2CARPRO JACK
  • 11,533 POSTS
Do they turn on when you open the passenger door?If so it may be bad switch in the drivers door. Have seen them get sticky, try using WD-40 to lube the latch assembly (this is where the other switch is as well) close and open the door a few times and let the lube work its way in. If they dont come on when you open pass door, you may have a problem with the body controller.
Aug 31, 2008 at 1:23 AM
