2000 Ford Focus idle
169,000 MILES • 4 CYL • FWD • MANUAL
CARLB92
Car starts but won't idle. I have to keep pumping the accelerator to keep it going
Typical problem?
May 15, 2010 at 12:51 AM
RENAUDTN
  • 636 POSTS
Is your check engine light on? Look for trouble codes. Also:
*Check your fuel pressure
*check/clean your IAC valves and motor
*check EGR valve,
*check PCV valve
*check/clean MAF sensor.
*check TPS sensor
May 17, 2010 at 9:31 AM
