2000 Ford Focus Hum or Whine
2000 FORD FOCUS
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHAYSLAW
Everytime i start my car it has this hum or whine sound coming from the engine. when i press on the gas petal to accelerate i still here this sound. Do you know what could this possiblely be?
Mar 8, 2009 at 8:40 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d95af4e7e4="shayslaw"]Engine Mechanical problem
2000 Ford Focus 4 cyl Two Wheel Drive Automatic 100000 miles
Everytime i start my car it has this hum or whine sound coming from the engine. when i press on the gas petal to accelerate i still here this sound. Do you know what could this possiblely be?[/quote:d95af4e7e4]
There are a couple possibilities...
1) belt needing replacement
2) Idler and/or Tensioner Pulley Bearings going bad.
To check the Pulleys just.. with engine off locate the pulley or pulleys. then with a can of spray lube spray the center bolt on ONE of the pulleys then start vehicle. If noise is gone replace that pulley. If noise is still there repeat proccess above on other pulley.
Mar 8, 2009 at 8:51 AM
