2000 Ford Focus hOW TO INSPECT REAR BRAKE SHOES
32,000 MILES • 4 CYL • 2WD • AUTOMATIC
TED MARKLE
have a 2000 Focus SE. I want to check the rear brake shoes. The manual says
that 4 bolts have to come off in the back. In older cars I just took off the
large nut that held the bearing in place. Do I need to take off the 4 bolts in
the back to check the brake shoes?
Aug 13, 2008 at 5:54 AM
BLACKOP555
  • 10,386 POSTS
there are bolts you have to remove to do so, there will be a star adjuster that will have to be backed off with a special tools to get the drum off if it feels locked on.
Aug 13, 2008 at 7:38 AM
