2000 Ford Focus HOW DO U CHANGE A TIMMING BELT AND LINE IT
DEMONSPYDER
2000 Ford Focus 4 cyl Front Wheel Drive Automatic
NEEDED TO FIND OUT HOW TO CHANGE A TIMMING BELT AND HOW TO LINE THE BELT UP RIGHT.BECAUSE I'M STUCK ON IT.AND IF YOU CAN ASNWER THIS I WOULD REALLY BE GREATFUL
THANKS DEMON
Apr 25, 2008 at 11:40 AM
  • 75,988 POSTS
Which engine do you have? 2.0 4cyl VIN B & 3 or 2.0 4cyl VIN P ? Below is for 2.0 4cyl SOHC VIN P Make sure you put engine no.1 piston on its compression stroke then line the sprockets then install the belt.
https://images.2carpros.com/forum/automotive_pictures/12900_timing_marks_2.jpg
Apr 25, 2008 at 11:54 AM
