This car will start and run fine for a while, but then stops running and will not start. Replaced fuel pump, but can a bad o2 sensor cause this?
Apr 26, 2010 at 1:13 PM
✓Experienced Mechanic
Chances are the O2 sensor will not shut the engine down. When it doesn't restart, have you checked to see if it is getting spark and fuel to the engine?
